We use the WS-6-MINI's for an MDU. To prevent shenanigans we have the ports disabled on the switch until a unit is ready to sign up, then we enable the port. On the Mini's, every time we activate the new sub and do all the powercode stuff, we have to reboot the switch or the user will not get internet access. This was going on for a year but it only affected a handful of subs so I didn't waste too much time on it.
We are now using a WS-12-250-AC at a second MDU and we are having to do a reboot for each new sub. A minor inconvenience but I hate to take people down on purpose if it's not necessary.
All these switches are using the latest RC4 candidate for firmware, and it's been happening since at least 1.4.9 with the Mini's
Anyone else run into this?
Possible bug with Port Enable?
- kfbr
Re: Possible bug with Port Enable?
I do not see this? In fact last night we had HEAVY rain come through all night and I wanted to stop traffic from trying to go back to the main AF24HD link and stay on the backup link so I logged into the switch and Disabled the port on the Ports TAB leaving the Radio powered up and then this morning I logged into the switch and simply enabled the port and traffic via OSPF immediately jumped to the AF24 main link.
Your going to have to post up all your config TABs and explain how to replicate this if you want Stephen to look into it.
intellipop - Member
- Has thanked: 7 times
Here is what the Ports tab looks like. Other than configuring the SNMP/Password settings there's not much else we do to these other than the VLANs.
Would a picture of a different tab or the config itself help?
intellipop - Member
It's actually pretty easy to see the issue. When we first enable a "new" port that's been disabled but part of a non default VLAN, and then check the MAC Table it shows that it's reporting the MAC on vlan 1, when it's not even configured for VLAN1 rather vlan 2xx. If I go to the VLAN tab, edit the VLAN to be default, save it, then switch it back all better. This is something we can re-produce on the 12 port AC, and the 6 port Mini. It's with isolation turned on for the port. I've not tested with Isolation off. But it's really clear that something isn't working as intended when you see the MAC for the port on the WRONG vlan in the MAC table, then check the VLAN table and note it's not even configured to use that VLAN.
Try v1.5.1.rc4 as there was some changes that could affect this then let us know.
Please always try the latest code as that is the version in development.
