Anyone seen this issue I get errors all across the board I tried a reboot and a firmware upgrade to latest version all same thing. I have not tried a hard power cycle yet? 24 volt DC system nothing changed in the last 200 + days?? Only reason we saw this was because our backhaul rebooted due to power reset. logged into netonix and we saw these errors??
EDIT HARD power cycle fixed the issue??? I also notice before the power cycle the fan RPM was around 8850 rpm its now down to hardly running. The switch was not even hot it was cool to the touch before the power cycle RPM now down to 2550
Jan 1 00:00:10 netonix: 1.4.9 on WS-12-250-DC
Jan 1 00:00:14 system: Setting MAC address from flash configuration: EC:13:B2:82:37:AA
Jan 1 00:00:17 admin: adding lan (eth0) to firewall zone lan
Jan 1 00:00:27 admin: Unable to query power supply
Dec 31 16:00:32 admin: removing lan (eth0) from firewall zone lan
Dec 31 16:00:36 admin: adding lan (eth0) to firewall zone lan
Dec 31 16:00:43 admin: adding lan (eth0) to firewall zone lan
Dec 31 16:00:44 STP: set port 1 to discarding
Dec 31 16:00:44 STP: set port 2 to discarding
Dec 31 16:00:44 STP: set port 3 to discarding
Dec 31 16:00:44 STP: set port 4 to discarding
Dec 31 16:00:44 STP: set port 5 to discarding
Dec 31 16:00:44 STP: set port 6 to discarding
Dec 31 16:00:44 STP: set port 7 to discarding
Dec 31 16:00:44 STP: set port 9 to discarding
Dec 31 16:00:44 STP: set port 10 to discarding
Dec 31 16:00:44 STP: set port 11 to discarding
Dec 31 16:00:45 STP: set port 12 to discarding
Dec 31 16:00:45 STP: MSTI0: New root on port 1, root path cost is 80110
Dec 31 16:00:45 STP: set port 1 to learning
Dec 31 16:00:45 STP: set port 1 to forwarding
Dec 31 16:00:45 STP: set port 5 to learning
Dec 31 16:00:45 STP: set port 5 to forwarding
Dec 31 16:00:47 STP: set port 11 to learning
Dec 31 16:00:47 STP: set port 11 to forwarding
Dec 31 16:00:47 STP: set port 10 to learning
Dec 31 16:00:47 STP: set port 10 to forwarding
Dec 31 16:00:47 STP: set port 9 to learning
Dec 31 16:00:47 STP: set port 9 to forwarding
Dec 31 16:00:47 STP: set port 7 to learning
Dec 31 16:00:47 STP: set port 7 to forwarding
Dec 31 16:00:47 STP: set port 6 to learning
Dec 31 16:00:47 STP: set port 6 to forwarding
Dec 31 16:00:47 STP: set port 4 to learning
Dec 31 16:00:47 STP: set port 4 to forwarding
Dec 31 16:00:47 STP: set port 3 to learning
Dec 31 16:00:47 STP: set port 3 to forwarding
Dec 31 16:00:47 STP: set port 2 to learning
Dec 31 16:00:47 STP: set port 2 to forwarding
Dec 31 16:00:48 STP: set port 12 to learning
Dec 31 16:00:48 STP: set port 12 to forwarding
Dec 31 16:01:05 UI: i2c error setting 0x47 12 110
Dec 31 16:01:26 UI: i2c error setting 0x47 14 122
Dec 31 16:01:26 system: starting ntpclient
Mar 20 14:28:45 dropbear[1511]: Running in background
Mar 20 14:28:47 switch[1539]: Detected warm boot
Mar 20 14:28:50 switch[1538]: retrying i2c link to power supply
Mar 20 14:28:53 switch[1538]: retrying i2c link to power supply
Mar 20 14:28:56 switch[1538]: retrying i2c link to power supply
Mar 20 14:28:56 switch[1538]: i2c link down to power supply (0)
Mar 20 14:29:00 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:03 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:06 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:09 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:12 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:15 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:18 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:21 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:25 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:28 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:31 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:34 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:34 switch[1538]: i2c link down, in recovery mode
Mar 20 14:29:37 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:40 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:43 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:46 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:49 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:53 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:56 switch[1538]: retrying i2c link to power supply
Mar 20 14:29:59 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:02 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:05 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:08 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:11 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:14 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:17 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:21 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:24 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:27 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:30 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:33 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:36 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:39 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:42 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:45 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:49 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:52 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:55 switch[1538]: retrying i2c link to power supply
Mar 20 14:30:58 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:01 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:04 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:07 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:10 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:13 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:17 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:20 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:23 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:26 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:29 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:32 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:35 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:38 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:42 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:45 switch[1538]: retrying i2c link to power supply
Mar 20 14:31:48 switch[1538]: retrying i2c link to power supply
Wisp Switch cant communitcate with power supply??
- Accel Wireless
Re: Wisp Switch cant communitcate with power supply??
Accel Wireless wrote:EDIT HARD power cycle fixed the issue??? I also notice before the power cycle the fan RPM was around 8850 rpm its now down to hardly running. The switch was not even hot it was cool to the touch before the power cycle RPM now down to 2550
Odd, sometimes shit just needs rebooted, it happens.
I hope your running at least v1.4.9 but I would suggest v1.5.0rc1 which was released with some important/good improvements.
- Accel Wireless
Yeah power cycle fixed it agree sometimes shit needs to be rebooted. It's nice how these things work so well but you never expect something to fail or glitch but such as life, still VERY HAPPY with these switches!!I upgraded to 1.4.9
