Do you have any documentation for the REST api? For example I found I can query syslog:
https://<switchip>/api/v1/syslog
or stats for a port:
https://<switchip>/api/v1/portdetail?port=1
Thanks,
Lac
REST api
Eric Stern - Employee
- Been thanked: 130 times
Re: REST api
Not at this time. Its a fairly simple API as you've already discovered. It should be pretty easy to figure out what you want to do by looking at how the web GUI uses the API or grabbing api.php from the switch and taking a look at it.
