v2.0.6rcX Bug Reports and Comments - WS3 Firmware
Been thanked: 207 times
Mon Mar 15, 2021 4:35 pm
Click HERE to download firmware v2.0.6rcX - RC4 Released 4/19/2021
Click HERE to go to the Download Latest Firmware thread
v2.0.6rcX wrote:FIXED/CHANGED
- fixed PoE changes on any port would briefly turn off PoE on all active ports - RC4
- In RC2, switch had difficulty accessing powered radios - RC3
- changing hostname in CLI or webGUI caused random behavior - RC3
- Management VLANs with tagged ports can now pass traffic - RC2
- updates to software to accommodate new hardware updates to improve OCP functionality
*** IMPORTANT NOTE*** This applies specifically for WS3's rev D and greater see this post - RC1
- selectable SFP+ speeds updated to include 1G - RC1
- Wattage/PoE popup balloons updating correctly for monitoring - RC1
- External Sensor monitoring error when removed from switch - RC1
ENHANCEMENTS
KNOWN ISSUES
- Some language templates need help - please private message Stephen Copeland to help
RC3 Released 4/17/2021
RC2 Released 3/15/2021
gnorton
Re: v2.0.6rcX Bug Reports and Comments - WS3 Firmware
Tue Mar 16, 2021 1:26 pm
Stephen,
The initial configuration change issues and management vlan access trouble I was seeing appears to be fixed!
I am Still seeing issues with connecting FS.com 10g sfp tranceivers.
I have to toggle between the port setting on the Netonix to 2.5g, save it, then back to 10g before it will register.
I have tried with autonegotiation enabled on the Mikrotik as well as setting the mikrotik interface for 10g only, but it doesn't seem to make a difference until after I save that 2.5g netonix setting. Once it registers, it seems to persist through subsequent reboot attempts without any further issue.
Both test switches we purchased have board C, so I will start the RMA for them.
Thanks,
Tue Mar 16, 2021 1:46 pm
Hey gnorton, thanks for your feedback. I'm glad it's working better for you.
I will add the odd behavior you're seeing with the 10G setting to the list of things we are tackling on the new switches.
Do you mind giving me the model number for the 10G sfp transceiver so I can acquire a couple?
Mon Apr 19, 2021 6:23 pm
ENHANCEMENTS
KNOWN ISSUES
gnorton
Fri Apr 30, 2021 5:11 pm
Stephen,
We were using SFP-10GLR-31-I transceivers from fs.com, and I also tried a mikrotik branded one but don't have the model off-hand.
Fri Apr 30, 2021 5:36 pm
Thanks gnorton, I have ordered a few to try out.
adairw
Has thanked: 98 times
Been thanked: 132 times
Wed Jun 23, 2021 9:10 am
Bug or Feature? We have a default gateway configured on a WS3 but can only access it at layer 2.
Garnet
Wed Jul 07, 2021 3:02 pm
Link to a thread discussing possible bugs: viewtopic.php?f=17&t=7045
