SNMP log file
Ludvik
Has thanked: 15 times
Been thanked: 15 times
SNMP log file
Tue Apr 30, 2019 7:50 am
Hi.
I noticed that the /var/log/snmpd.log file is 11 MB big on my switch.
Code: Select all
admin@curve1:/www# ls -l /var/log
-rw-r--r-- 1 admin root 0 Jan 1 1970 lastlog
drwxr-xr-x 2 admin root 0 Mar 25 01:20 lighttpd
-rw-r--r-- 1 admin root 245 Apr 29 18:06 messages
drwxr-xr-x 2 admin root 0 Mar 25 01:20 radius
-rw-r--r-- 1 admin root 11028919 Apr 30 13:41 snmpd.log
-rw-r--r-- 1 admin root 0 Jan 1 1970 wtmp
Contains a large number of records:
Code: Select all
No MemShared line in /proc/meminfo
It is always created after querying OID .1.3.6.1.4.1.2021.4.6.0
What happens when the free space is completely occupied?
Code: Select all
Filesystem Size Used Available Use% Mounted on
rootfs 5.8M 5.8M 0 100% /
/dev/root 5.8M 5.8M 0 100% /rom
/dev/mtdblock6 4.3M 1.2M 3.0M 28% /jffs
mini_fo:/jffs 5.8M 5.8M 0 100% /
Been thanked: 210 times
Re: SNMP log file
Tue Apr 30, 2019 2:25 pm
Would you mind running the command:
Code: Select all
cat /var/log/snmpd.log
And sharing the output?
I'm wondering if this might be another piece to the puzzle on the other issue we're dealing with that seems to be related to discovery.
Ludvik
Re: SNMP log file
Tue Apr 30, 2019 2:56 pm
317632 lines ...
Code: Select all
Cannot find module (IP-MIB): At line 0 in (none)
Cannot find module (IF-MIB): At line 0 in (none)
Cannot find module (TCP-MIB): At line 0 in (none)
Cannot find module (UDP-MIB): At line 0 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 0 in (none)
Cannot find module (SNMPv2-MIB): At line 0 in (none)
Cannot find module (SNMPv2-SMI): At line 0 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 0 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 0 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 0 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 0 in (none)
Cannot find module (SNMP-MPD-MIB): At line 0 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 0 in (none)
Cannot find module (TUNNEL-MIB): At line 0 in (none)
Cannot find module (UCD-DLMOD-MIB): At line 0 in (none)
Cannot find module (IPV6-ICMP-MIB): At line 0 in (none)
Cannot find module (IPV6-MIB): At line 0 in (none)
Cannot find module (IPV6-TCP-MIB): At line 0 in (none)
Cannot find module (IPV6-UDP-MIB): At line 0 in (none)
Error opening specified endpoint "udp:161"
Server ExitingNo MemShared line in /proc/meminfo
... last line repeated 317610x (as I said).
Other piece of switch: 883756 lines.
I do not have this monitoring on all of netonixes. These pieces have snmp log almost empty. This is *probably* not our memory problem.
Re: SNMP log file
Tue Apr 30, 2019 3:24 pm
Sorry I know you did say that, I just wanted to see the difference between what I'm seeing on mine and this one.
The only lines that are different are these:
Code: Select all
On mine, the very next line should be:
Code: Select all
NET-SNMP version 5.1.2
It appears that port 161 is already being used by something which is blocking snmpd from starting, possibly causing it to continuously restart. Or, it is locking it into a error state and whenever it is queried it shows that error message.
See if you can get the output for the following:
Code: Select all
ps | grep snmp
On mine, the result should be
Code: Select all
969 admin     5292 S    /usr/sbin/snmpd -Lf /dev/null -p /var/run/snmpd.pid
Also, to be safe, there should be no severe consequence if you remove that log file, it will just re-create it when it needs it:
Code: Select all
rm /var/log/snmpd.log
Ludvik
Re: SNMP log file
Tue Apr 30, 2019 4:14 pm
snmpd is running. I have graphs ... you see it in other thread. IP 10.106.30.74 is visible in graph header. 1.5.2rc6
Code: Select all
 1083 admin 5488 S /usr/sbin/snmpd -Lf /dev/null -p /var/run/snmpd.pid
This is another switch, also monitored (1.5.0), 884063 lines:
Code: Select all
Deleting file is only temporary solution (but file is not recreated). You need solve error and implementing logrotate.
Ludvik
Re: SNMP log file
Tue Apr 30, 2019 6:03 pm
It was not re-created after deleting the log file. I tried "kill -HUP" and hoped to reload the configuration and create a log file.
But the process was killed ... and after a few seconds started: Apr 30 23:49:30 monitor: restarting snmpd
However, I was very surprised at the status of RAM occupation. Instead of 106MB, now only 74!
I myself wonder what will eventually be a mistake. Later I try it on another switch.
Ludvik
Re: SNMP log file
Tue Apr 30, 2019 6:28 pm
Test on 10.106.30.74
The CPU usage is strange. I didn't do anything, just checked the log file and got the WEB-GUI open. I would like the htop program to be part of the firmware.
At this state i remove log file and reload snmpd.
Result:
My management system also simply check STP root port and bridge. OID .1.3.6.1.2.1.17.2.5.0. Before reload snmpd it has value 65535 as root port and own MAC as root bridge. After reload it is port 0 and 00:00:00:00:00:00 as root bridge. I have STP disabled. It is strange.
Re: SNMP log file
Tue Apr 30, 2019 6:35 pm
Well part of this I suspected actually - I am really beginning to suspect that the issue we've been attributing to discovery may actually have to do with snmpd.
The error:
Code: Select all
Is probably happening because when your snmp client is querying the device for OID .1.3.6.1.4.1.2021.4.6.0
Which, is the amount of free memory available, net-snmp might be trying to make a call to a MemShared variable in meminfo which does not exist on the version of the kernel we have to use. I took a look around and apparently this is not an unknown possibility with net-snmp.
I think we may very well have found the source of the memory leak we've been hunting.
