I haven't found this reported on the forms for the 1.4.9 firmware, but I believe there is a memory leak somewhere.
I've got a few WS-12-250-DCs across my network and I'm seeing the free memory all both of them slowly drop over the period of about 10 months.
Possible Memory Leak - FW 1.4.9
- zdsimpso
Re: Possible Memory Leak - FW 1.4.9
Well considering we are on version 1.5.0 or v1.5.1rc7 try upgrading the units and see what happens.
v1.4.9 is closed an no further development will occurr. However a lot of people are using v1.4.9 and not reporting this.
Also there are security holes in v1.4.9 so maybe if your switches are accessible by web they are hacked?
I have some switches using v1.4.9 that have been up for over a year.
I'm showing memory leaks in 1.5.0. One device that's been up 111 days. Originally had 38% memory in-use post-reboot, now 51%. It's slowly trending up for sure.
I have several switches that are up for over a year. It's hard for me to get much more than that as I have to constantly upgrade some units to test and I also want the security patches in the newer firmware.
Eric did say memory will grow a bit over time as the switch uses it for stuff (technical terminology) but there is no memory leak that will cause a problem. We had a real memory leak that did cause an issue many versions ago but was fixed.
Users browsing this forum: No registered users and 94 guests
