Post install pictures of your WS-12-250X or WS-24-400X in the Share Your Installation Pictures under WISP Switch or click here to be directed there.
Rules:
Must show a picture of the switch installed. (Don't be shy all of us have wiring from hell)
Must show a screen capture of your WISP Switch Status Tab and any other Tab you want to share.
Switch must be running v1.1.X firmware which can be downloaded here
Post are only eligible is created on or after 1/23/2015 until the day after the WS-8-250-AC is released for sale (probably end of next week).
You must also make a post in this thread indicating you are entering your post into this contest with a link to your post.
The Post with the most likes when the switch is posted for sale wins a free WS-8-250AC WISP Switch.
Good Luck!
I also want to remind people about the use of Flow Control, please read this post: viewtopic.php?f=6&t=187&start=70#p2582
WIN a FREE WS-8-250-AC - CLOSED - NO ENTRIES
REALLY
What the hang, over 500 switches out there in service and no one wants to post pictures of their installs to win a FREE WS-8-250-AC switch?
Re: WIN a FREE WS-8-250-AC
IKWYM waddup widdat?
I already have my story posted viewtopic.php?f=14&t=267 and I figure that there is someone more deserving that could use a free switch so I'm sitting this one out.
Lemme know when the Mini Tower comes up for contest.
WS-6-MINI
If you guys want to see what the WS-6-MINI looks like click here.
The 6 port mini is fed power via POE uplink (port 1). You can it power from one of the 48VH ports from our switches which can feed it about 1+ amps constant draw. Now later revisions of our larger switches will have the ability to feed 2 Amps from a 48VH port.
Or you can feed it with a 1.2 or 2 Amp power brick that we will also sell or there are other manufactures out there that offer one.
Even though the switch is small it has the exact same switch core, CPU, memory, flash as their larger WISP Switch cousins so it uses the exact same firmware.
If you are feeding it with 2 Amp it has the ability to power an airFIBER/Exault/Mimosa radio using port 2 which only has one POE option which is 48VH.
Now ports 3,4, 5 and 6 allow 24V or 48V POE options to power airMAX or other radios.
Eventually we will make the firmware of the switches detect that a MINI switch is being powered by it and allow you to configure the MINI switch from the primary switch.
A WS-24-400A could power up to 4 MINI switches.
The WS-6-MINI is designed to fit inside the Tycon power box shown here.
If you are designing a MICRO POP this switch could be mounted up on the building and run a single wire down inside the building to a 2A POE brick and then plug the customers AP into the injector. Up on the roof you would mount the Tycon Power box with the WS-6-MINI inside where port 2 powers an airFIBER or Mimosa back haul and then also up to 4 other 24V or 48V radios.
The WS-6-MINI is approximately 4.75" x 4.75" x 1"
- Has thanked: 188 times
- Been thanked: 64 times
I like the 3D image. Are the holes on the side that go all the way through for mounting? If so, that is a great feature!
wayneorack wrote:I like the 3D image. Are the holes on the side that go all the way through for mounting? If so, that is a great feature!
Yes, the 6,8, and the new small 12 all have through hole mounting.
Although the first 100 8 ports you have to work at it because the chassis did not line up exactly right but we fixed it for the next batch.
WisTech - Associate
- Has thanked: 9 times
Pretty exciting man! Still waiting for DC, but love seeing these hitting the market quickly!
adairw - Associate
- Has thanked: 98 times
- Been thanked: 132 times
ah man, I haven't been watching this thread and i've posted two of the switches I've installed!
Users browsing this forum: Google [Bot] and 7 guests
