There are 4 ways to factory default our switches listed below, not all are the same.
The blue ones all achieve the same end result but the red one is different.
Most embedded devices running Linux behave the same way.
Web UI - Click Utilities/Default
This erases not formats the writable JFFS2 partition on the flash and generates a new config file.
This does not fix errors on the partition like bad blocks.
CLI - type "reload defaults"
Press the factory default button with a paper clip when the switch is already on and hold
This way produces a cool light show where all the port LEDs turn green in a loop and then they loop around red while you are pressing and holding the default button.
If you release the button right after the green loop the switch just reboots.
If you release the button right after the red loop the switch erases the JFFS2 partition and recreates the config with the defaults.
Press the factory default button and hold for 20 seconds when powering up
This feature reformats the writable partition where the config is stored then recreates a new config with the default, this process is actually handled but the boot loader. If you ever see an error or warning on the console during initial boot or in the Linux system log about the JFFS2 filesystem such as a checksum issue this is the only way to correct that issue. Now the JFFS2 file system is pretty resilient and even if it gets corrupted 99.9% of the time you would never have an issue but if you really want the error message to go away you have to do this type of factory default, just remember to backup your config or write it down first as with any factory default your config is lost!
WHEN PREFORMING THIS DEFAULT YOU MUST LET THE SWITCH SIT FOR SEVERAL MINUTES
Not all factory defaults are created equally
- Been thanked: 1362 times
soundwavz - Member
Re: Not all factory defaults are created equally
where is the factory default button the ws6poe?
soundwavz wrote:where is the factory default button the ws6poe?
Little round hole back of unit where the barrel connector is
If you do the full factory reset for the 20 seconds when powering up, is there any indication it's ok.. I've just done it on one of my spare switches, and if you do a normal reset after it's powered on the lights cycle green then red, however on the full factory nothing seems to happen?
bpnz wrote:If you do the full factory reset for the 20 seconds when powering up, is there any indication it's ok.. I've just done it on one of my spare switches, and if you do a normal reset after it's powered on the lights cycle green then red, however on the full factory nothing seems to happen?
Of you do the default button at power up you need to let it set for several minutes as it is formatting the flash else you will brick it.
If this model has a serial console cable maybe hook up a console cable and see what it doing.
Will test that with a serial cable and see what’s happening.. I ended up trying it on three switches and yep definitely let them sit for 10 mins or so before touching them again..
I just wanted to make sure the switches were 100% factory as I was looking into an issue when restoring config files to different model switches (will post a seperate topic about this once I’ve finished looking into it..)
Users browsing this forum: Baidu [Spider], Google [Bot] and 38 guests
