New question. Assuming I can find a passive injector that outputs more than 50V will the UBNT Ethernet Surge Protector still work? The spec sheet from UBNT does not list what voltages it supports, but the photo for it on the https://www.ubnt.com/products/#all/accessories page shows 15v, 24v, 48v and 50v support.
Would I be correct to assume anything higher than 50V output will not work with the UBNT protector?
WS-6-MINI 48V Out of Range?
- Has thanked: 1675 times
- Been thanked: 1358 times
Re: WS-6-MINI 48V Out of Range?
It should work fine, this is not how surge protection works or clamps down.
sbyrd - Experienced Member
- Has thanked: 16 times
- Been thanked: 26 times
lligetfa wrote:Tycon PoE supplies for AF are 56V so the 6 extra volts should make up for the line loss. I wonder if the following one would work?
http://tyconpower.com/products/files/TP ... _Sheet.pdf
TP-POE-HP-48G 120/240VAC Input, 56V 50W Gigabit Output
The one you linked to seems to be power on only 4 wires. This one however seems to be all 8 http://tyconpower.com/products/files/TP-POE-HP-56G_100W_POE_Inserter-Spec_Sheet.pdf. However, it seems power is 1,2,7,8 (-) and 3,4,5,6 (+). Will that work, or maybe this one https://www.streakwave.com/mmSWAVE1/Video/TP-POE-HP-56G-FBN%20Spec%20Sheet%20Rev%202.pdf ?
Sirhc, again forgive my ignorance on power, but any assistance on whether this will work or not would be appreciated.
sbyrd wrote:lligetfa wrote:Tycon PoE supplies for AF are 56V so the 6 extra volts should make up for the line loss. I wonder if the following one would work?
Do not worry about polarity pinout so long as they do not put 2 polarities on the same pair as the WS-6 mini will correct polarity mismatches across pairs
Pair 1 = pins 1 and 2
Pair 2 = pins 3 and 6
Pair 3 = pins 4 and 5
Pair 4 = pins 7 and 8
Ok. Well depending on the response from Midspans on their POE injector it looks like my best option (at least until Netonix releases their own) is to use the Tycon TP-POE-HP-56G as it is 56V with 1.8A on all 8 wires. http://tyconsystems.com/index.php/ac-pa ... poe-hp-56g
It is a little pricey, but I can get it on Streakwave and I will more than make it back on the monthly price I get from the client on this PtP link. I am just not comfortable running the switch with it reading ~42V on the 48V meter. And this is with the switch and radios basically "idle" as the client has not started using the link yet.
Well I ordered the Tycon TP-POE-HP-56G from Streakwave. I will update once I get it installed.
CKalis - Member
- Has thanked: 3 times
sbyrd wrote:Well I ordered the Tycon TP-POE-HP-56G from Streakwave. I will update once I get it installed.
Any news on that POE device you installed? Is it still in use or have you used a different one? Wondering for my own uses.
I recommend this POE adapter if you need more power
https://www.streakwave.com/Itemdesc.asp ... V-80W&o1=0
