Hello, we use the port isolation feature to reduce broadcast domains on a site between sectors,
It can be useful to have protected port groups,
For example you have sectors on on ports 9-20 you want to isolate them from each other so you would put them in isolation group1
and then you may have a number of uplinks from 21-23, but you dont want to create a loop / broadcast storm / between ports 21-23 you would put them in isolation group2
so any port 9-20 can communicate with any port 21-23 and vice versa,
but ports 9-20 are isolated from each other
and ports 21-23 are isolated from each other
This rationale is used in many switches as protected port groups
switchport mode protected group 1
switchport mode protected group 2
or in software bridges as a bridge port horizon value... (ports with the same horizon value are isolated from each other )
add multiple protected port groups granular isolation
- wirelesscon
- Has thanked: 4 times
- Been thanked: 4 times
1 post
