RS232 as remote serial port for input
smaro
Tue Mar 19, 2019 3:52 am
Hi
Is there a way or some plans to use the serial port as normal remote serial to tcp proxy. I like to read remotely some RS232 input for diagnostics and use it on my windows PC. At the moment I can only see modbus. Are there some plans to realice this in the future?
Regards
Elmar
sakita
Has thanked: 111 times
Been thanked: 90 times
Re: RS232 as remote serial port for input
Wed Mar 20, 2019 10:56 am
Yeah, this is something I've wanted for a while... just give us a straight TCP to serial option... and, while the programmer is in there, go ahead and add UDP option as well (with auto return messages to last address received from).
