Hyphen & Colon
nasked
Been thanked: 3 times
Hyphen & Colon
Wed Jul 25, 2018 8:06 am
Hi:
As you know mikrotik uses colon to separate MAC. In MAC Table tab you must enter MAC separated with Hyphen to find some MAC. It would be good, search MAC with Colon too. :hurray: then you can copy and paste a MAC from mikrotik to Netonix. :lol:
Re: Hyphen & Colon
Wed Jul 25, 2018 8:16 am
If something must be done about it, I think it should accept any format just like the Wireshark MAC OUI tool. Maybe ignore colon, hyphen or any special caracter ? By exemple, Huawei use the following particular format of mac address on Smart AX serie (xPON/DSL):
XXXX-XXXX-XXXX
Banana Jack
Has thanked: 50 times
Been thanked: 13 times
Re: Hyphen & Colon
Mon Nov 05, 2018 8:41 am
Great suggestion. Huawei are clearly crazy but UBNT uses colons, like Mikrotik.
+1 from me.
Glenn
Been thanked: 209 times
Re: Hyphen & Colon
Mon Nov 05, 2018 10:44 am
Adding this to the next release.
Re: Hyphen & Colon
Mon Nov 05, 2018 12:43 pm
Fortunately, this one was pretty simple.
1.5.1rc8 has this feature added.
Download: viewtopic.php?f=17&t=240
Change log: viewtopic.php?f=17&t=3914&start=50
Banana Jack
Re: Hyphen & Colon
Mon Nov 05, 2018 3:19 pm
Hurrah!! Thank you Stephen :)
