It's time for outdoor DC wisp switches.
WS-12-250-DC-OUTDOOR
A nice aluminum body with a heatsink-style design.
Why?
Powerbox Pro
EP-R6
EP-R8
EP-S16.
These are all great concepts but they all miss something.
Powerbox Pro-
one voltage (input volts passed through), only 4 PoE outputs. Too Small
EP-R6-
like Powerbox Pro except one extra port.
EP-R8-
single voltage 54V, can power 24v BUT 54v means a change to most battery kits. 7 powered ports is the bare minimum...
EP-S16
same as R8 without the just-enough port count.
WS-12-250-DC-OUTDOOR:
12 powered ports is *just-right for many wISPs
DC-DC converter allows for existing power designs to be used, HUGE plus
2 SFP is *perfect* for connecting to router of choice in a router-on-a-stick design with a lag group.
console port... These are underutilized. I've been building Particle.io boards with a serial level converter and a cell connection to plug in which lets me work on these "no matter what" happens to the data links.
Accessories:
A netonix branded resettable breaker with a form-fit connector for the screw posts.
Alternatives:
Do the exact same thing with the WS-12-DC but make an accessory that is a DC-DC supply... like you cut a WS-12-250-DC into 2 parts, ws-12-DC and '250'...
Time for a NetPoint, NetBox Pro, whatever...
- Has thanked: 31 times
- Been thanked: 136 times
1 post
