Hi:
"show vlan", show us a vlan table, but i can't see the trunks port configuration. To see it i use "show config" and read all configuration.
It could be fine, an instrucction in cli interface like "show trunk" or attached the trunk information in the same instrucction "show vlan"
Thank You.
CLI AllowedVlan
Eric Stern - Employee
- Been thanked: 130 times
Re: CLI AllowedVlan
Then, just like HP, we should be able to create trunk and then associate it to the port since several ports can have the same trunk config.
nasked - Member
- Been thanked: 3 times
Re: CLI AllowedVlan
mike99 wrote:Then, just like HP, we should be able to create trunk and then associate it to the port since several ports can have the same trunk config.
