Alternative to WS-8-150-DC and WS-MINI
Charlie
Has thanked: 5 times
Sat Sep 02, 2017 7:48 pm
I would like to see a replacement for the MINI
- An 8 port MINI with proper DC jacks and a bigger voltage input range instead of just 48v. Eg. 9-72v
- No SFP ports
- A 10A relay switch
- Chassis temperature sensor for monitoring cabinet temperature
- Control ports, DC output or relay switch with time as well as temperature sensors
Currently one port is used by the RB750 mikrotik and 90% of our high sites are solar powered on a 24v battery bank with 5 radios so we havent been able to buy the MINI for a network wide rollout.
The WS-8-150-DC is the next best model but it has SFP ports which are overkill and still only 6 ethernet ports.
We also want to be able to control devices by the temperature sensor for a cabinet fan. Ideally if this didnt use a ethernet port and just had a 10A relay switch that would be awesome.
Been thanked: 159 times
Re: Alternative to WS-8-150-DC and WS-MINI
Sat Sep 02, 2017 7:59 pm
i am working on next gen designs, which should make you a happy camper..........
hopp
Mon Sep 11, 2017 11:46 pm
I'd like all of the above please and also an i2c bus exposed or ADC 0-5v that SNMP can log.
