Feature Request : Temperature POE control
theteksolution
Has thanked: 6 times
Fri Mar 10, 2017 12:21 am
Hi. We are powering our cabinet fans successfully via POE and would like to be able to automate POE power status based on temperature readings. Dont think this should be very complicated to implement. What do you think?
Thanks! Charles... Pirate2
Re: Feature Request : Temperature POE control
Sat Mar 11, 2017 12:21 am
You could do it yourself if you want. You could use a temperature sensor (or snmp to monitor temperature board) and use the REST API to enable or disable PoE.
viewtopic.php?f=6&t=2216&p=15793
Sat Mar 11, 2017 5:11 pm
If all you want to do is turn the fans on and off, I say why complicate it? Wire a mercury bulb thermostat in series.
Sat Mar 11, 2017 5:24 pm
If you monitor the PoE watts drawn, you would know when the temp is above the thermostat set point. If you have multiple fans and multiple thermostats and you set each thermostat at a different setpoint, you could deduce the temperature by deducing how many fans are running by looking at the wattage drawn.
Sat Mar 11, 2017 6:01 pm
We can add a feature where the POE to designated port(s) is turned ON and OFF to control box fans but this would be based on board temp which I am not sure would be very useful?
There was a time when I requested external sensors but was told would not be very useful.
I had envisioned these external ports:
Open door sensor
Temperature
24V/48V port for external fans - programmable based on external Temp and time.
jakematic
Has thanked: 362 times
Been thanked: 87 times
Sun Mar 12, 2017 9:25 am
lligetfa wrote:If all you want to do is turn the fans on and off, I say why complicate it? Wire a mercury bulb thermostat in series.
I've done this with inexpensive snap discs http://www.mouser.com/Thermal-Managemen ... sc&FS=True
An I2C sensor or NTC thermistor would cost me pennies to add, if an external port was on the Netonix.
Right now an mFi-mPort + mFi-THS is costing me half of what a WS-8-150-AC does, and a third of a WS-12-250 :yikes:
And it's clunky as shit HW requiring obsolete SW... got 6 of them... each one within arms reach of a Netonix...
So I think there is value there, but the community at large would need to chime in.
Edit: One of those does actually monitor a door, and control devices based on temperature...
theteksolution
Mon Apr 24, 2017 5:10 pm
POE power based on board temp would be perfect. Were literally just trying to keep the netonix cool in a metal cabinet.
sirhc wrote:We can add a feature where the POE to designated port(s) is turned ON and OFF to control box fans but this would be based on board temp which I am not sure would be very useful?
Open door sensor
Temperature
Mon Apr 24, 2017 5:18 pm
We can do a firmware feature where we turn POE ON and OFF for a port that you use to control a fan then use this to power the fan:
https://www.streakwave.com/Itemdesc.asp ... erTap&o1=0
We may put this in v1.4.8 once we start with that thread.
theteksolution
Mon Apr 24, 2017 5:51 pm
Awesome! Thank you!
theteksolution
Tue May 01, 2018 8:18 pm
sirhc wrote:We can do a firmware feature where we turn POE ON and OFF for a port that you use to control a fan then use this to power the fan:
Is this still in the works? Thx, Charles....
