24 VH WS-24-400-A ?
I hope to find this option in a new firmware... pse...Thank you.
There are a lot of AF5x being installed, and those are 24v. I would think two might not be enough.
The AF5X can be powered by:
24V up to 160 feet +/- of cable < Least prefered method
48V up to 200 feet +/- of cable < Better method
24VH up to 326 feet +/- of cable < Even better method
48VH up to 326 feet +/- of cable < Preferred method
The AFX radios can actually use all 4 POE options we have as seen above.
but I always take note about tec. Spec..before connect any device...they are very expensive
...and af5x data sheet and poe that comes inside box is 24v 1Amp. Users browsing this forum: No registered users and 9 guests
