Netonix switch with Cambium style sync support built in
tcknudson
Has thanked: 4 times
Been thanked: 22 times
Fri Nov 04, 2016 9:43 am
We have moved mostly to Netonix and sync becomes a real issue,
moving from cmm and ctms, depending on 450ap's built in sync (which disappeared in 450i AP).
Older towers using Packetflux items to insert sync after the fact. (still an issue with 450i AP (no RJ11 port on this one))
have a tower upgrade on hold looking for reasonable solution.
Otherwise we have to start migrating back to cmm4 and CTM2.
Re: Netonix switch with Cambium style sync support built in
Fri Nov 04, 2016 10:13 am
Is Cambium sync documented to be implemented in other switch than paquetflux ? You could use the universal GPS module.
http://community.cambiumnetworks.com/bs ... FANOUT.pdf
Eric Stern
Been thanked: 130 times
Sat Nov 05, 2016 9:57 am
It depends on exactly what you want it to do. If all you would like is for the switch to operate as a Transparent Clock as per IEEE 1588-2008, then I think I can add that pretty easily.
If you had hoped it could act as a Grandmaster clock, then no, since the switch does not have a GPS receiver to act as the timing source.
jluthman
Thu Nov 17, 2016 1:10 pm
Could you build one that does?
Thu Nov 17, 2016 10:09 pm
Why not just use the universal GPS module ?
mark
Sun Dec 23, 2018 9:23 am
I am using a Ugps from cambium to provide sync to 2 pmp100 on a Netonix switch
But think I need to enable ios on the ugps and the 2 ap because I am having problems with connecting to them
I am having no problem with the bridge and the other ap pmp100 with has its own sync cable
