Carbon Fibre RF Armor
Simple - Member
- Has thanked: 4 times
- Been thanked: 5 times
How about an RF Armor style kit made of carbon fibre that snaps together on a pre-existing dish, Like an "otter box". Think of snapping it together on a tower. Plus huge wait loss. You could use RAM(rf abosorbant materials) to in-lay the pieces and paint it with RAM coating that is UV stabalized for extra isolation. I think absorbtion of RF energy in co-local situations may be a bigger advantage than say reflection. Since I cannot see what happens to the energy when it is reflected off of the metal surfaces of the RF Armor kits, I assume, it bounces off and sprays out everywhere. I addmit I am not an engineer, but this should get a conversation started.
Re: Carbon Fibre RF Armor
Reflecting has it advantages on the sector kits where it cleans up the edges to 3 dB down points from 6dB.
I think the metal also serves to carry away heat.
