Diode Bridge on DC switch inputs
metroplex
Thu May 12, 2016 8:58 am
Is there enough room inside to stick a diode bridge on the inputs so we could power the WS-12-250-DC via AC low voltage?
This would also make reverse polarity a non-issue.
-Mike
rebelwireless
Has thanked: 31 times
Been thanked: 136 times
Re: Diode Bridge on DC switch inputs
Thu May 12, 2016 9:39 am
seems like a very specific need... you could just put the rectifier in-line if you want to push low voltage AC....The advantage of AC is that it's moderately safe at higher voltage, so you can keep amps down on a wire and run it distance... low voltage AC offers very little...
it would be nice to have polarity protection on the DC input though...
Thu May 12, 2016 10:27 am
I pinged Dave on this.
I think the new WS-8-150-DC has reverse polarity protection but is still not an isolated power supply for safe operation on negative 48V DC sites which is expensive to implement for such a small number of users but we keep talking about it.
Been thanked: 159 times
Thu May 12, 2016 1:51 pm
our new WS-8-150-DC has polarity reversal protection, hook it up the way ya to in regards to polarity...and always bear in mind the negative input is also our negative output, so our POE is not isolated electrically from the DC input power.
in regards to putting a bridge rectifier internally, you will void the warranty, so I am not going to recommend it. if you want to put one outside the box, i guess you could if you want to, but depending on your load, the bridge rectifier will heat up a lot....
rebelwireless
Thu May 12, 2016 3:33 pm
I wasn't recommending putting the rectifier in the case... just in-line before it inputs.. if low voltage AC is really wanted..
Geeky907
Tue Jul 27, 2021 9:25 pm
Mabie Sell a Banana Plug to Binding post Full-wave bridge rectifier module as an accessory :)
sakita
Has thanked: 111 times
Been thanked: 90 times
Wed Jul 28, 2021 2:32 pm
Curious. So are you thinking of using 24VAC (which is common in some security applications, for example) with a bridge rectifier to provide unfiltered DC?
If the power supply doesn't mind dirty DC and you have > 6A capacity in the wiring and rectifier it shouldn't turn into an ElectroBOOM episode ("Full Bridge Rectifier") :lol:
