10G uplinks
expohl
Been thanked: 15 times
10G uplinks
Sun Feb 14, 2016 6:18 pm
I could really really use a DC switch with 10G uplinks! I know this has been mentioned before but I want to make another post.
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Re: 10G uplinks
Mon Feb 15, 2016 5:11 am
I could use an only SFP and SFP+ port switch. Model A: 12 ports SFP + 2 ports SFP+ Model B: 20 port SFP + 4 port SFP
wayneorack
Has thanked: 188 times
Been thanked: 64 times
Re: 10G uplinks
Mon Feb 15, 2016 11:30 am
I have been wondering about this switch.
http://community.ubnt.com/t5/EdgeMAX-St ... -p/1467889
Would they really build this switch without SFP+ ?
Are we being left in the dark, or are they that far out of touch?
rebelwireless
Has thanked: 31 times
Been thanked: 136 times
Re: 10G uplinks
Mon Feb 15, 2016 1:57 pm
out of touch. I mean, 12x 1Gb ports with no high capacity uplink? What are you supposed to do? use 6 ports and LAG 6 together? LAG the 4 copper ports to have a 3:1 deficit in uplink?
I get it to some degree, if you were fiber feeding radios on the tower then you might not really be using the 1Gb capacity... but how many ubiquiti radios are fiber fed? -zero-
The only think tower side with fiber they have is the EdgePoint units, but those have switch ports so I'm no seeing the benefit of a rack mounted SFP only switch.
This thing should absolutely have 2 SFP+ ports.
ANY 12 SFP ports needs 2 SFP+ ports for uplink.
Weird.
wispwest
Has thanked: 7 times
Been thanked: 10 times
Re: 10G uplinks
Thu Dec 01, 2016 11:04 am
We're deploying a Siklu 70/80Ghz 5Gb FDD backhaul link to one of our main tower sites this month, and I could've swore that the Netonix had SFP+ 10G ports. Guess I'll just have to use a Mikrotik CCR
jowang
Re: 10G uplinks
Tue Dec 13, 2016 2:16 am
I have been using the Cisco 4500 switch for 10G network. I admire the VSS feature of the switch most. Also I have bought several SFP+ modules from fs.com. They are just fully compatible with my original devices.
Re: 10G uplinks
Sun Aug 13, 2017 12:56 pm
wispwest wrote:We're deploying a Siklu 70/80Ghz 5Gb FDD backhaul link to one of our main tower sites this month, and I could've swore that the Netonix had SFP+ 10G ports. Guess I'll just have to use a Mikrotik CCR
The WS2 line is due to be released in Q1 2018 which will have SFP+ ports and possibly some copper 10/100/1000/10G ports
JDH51086
Re: 10G uplinks
Sun Aug 20, 2017 1:17 pm
Really looking forward to the WS2 line. Not that they're difficult to work with at all as is, but having a 10G SFP+ uplink port or two would make some of our future builds so much easier!
Been thanked: 159 times
Re: 10G uplinks
Sun Aug 20, 2017 1:33 pm
in progress............
Brough
Been thanked: 9 times
Re: 10G uplinks
Thu Oct 26, 2017 2:50 pm
I'm extremely interested in one or better two SFP+ ports. Increasingly, we're using 2-5 Gbps radios (70/80 GHz) on backbone routes (rings) dropping off Gbps connections at intermediate buildings. So we need at least two SFP+ ports.
How do I get on the beta?
