RF Armor sector mount for 4.5" OD pipe
jsweere
Fri Oct 23, 2015 1:17 pm
We have a lot of sites that could benefit from an item just like the UCM3T, but for a 4.5" OD pipe.
Re: RF Armor sector mount for 4.5" OD pipe
Fri Oct 23, 2015 1:45 pm
jsweere wrote:We have a lot of sites that could benefit from an item just like the UCM3T, but for a 4.5" OD pipe.
You could order some custom made but if they are not in large volumes could be 2X or 3X the cost made in small quantities.
jsweere
Fri Oct 23, 2015 1:51 pm
I figured as much...anyone know of any similar product?
This could work, but is pretty overkill for the airMAX sectors w/ RFArmor...
http://www.mccowntech.com/3p-36-sector- ... -36-masts/
Fri Oct 23, 2015 2:33 pm
You could always use a short standoff and let the main 4.5" mast sit between the sectors.
jsweere
Fri Oct 23, 2015 3:00 pm
Thats probably what I'll end up with. Thanks guys!
adairw
Has thanked: 98 times
Been thanked: 132 times
Fri Oct 23, 2015 8:39 pm
yep, pipe to pipe clamps and stand off a piece of 2-1/2 inch pipe and mount the cluster to that.
