POE on the Customer Ap
Rbacon - Member
Not being able to view the spec sheet on this yet I was wondering if the user / I can turn off the POE so if they leave my service they would be able to use this for another application?
- Been thanked: 1362 times
Re: POE on the Customer Ap
Yes, we do not build anything half way, it is fully controllable like the POE ports on our switches.
You can set up ping watch dogs and have it reboot your CPE radio if it loses connection. You can also specify a wait period after reboot so it does not sit there rebooting your device over and over again because the tower is down.
I can't seem to find what wifi chipset it has in it or even if its an N or AC radio. I'm also having trouble finding it for sale anywhere. Is this still in dev at this point?
russman wrote:I can't seem to find what wifi chipset it has in it or even if its an N or AC radio. I'm also having trouble finding it for sale anywhere. Is this still in dev at this point?
Yes in development "still"
Atheros 9341 MIMO 2X2
