Hi!
Am getting an error while trying to install netonix manager 1.0.15 on centos nodejs. This is after running run "node bootloader.js"
Error: no such file or directory, open netonix-manager/storage/configs
Kindly assistme someone.
Thanks.
Need a help
- 1Tap
- roundcubetwo
Re: Need a help
please try re-downloading the tar file and extracting it again.
Once that is done, run the following commands:
export NODE_ENV=production
node bootloader.js
node bootloader.js
- braveone
Re: Need a help
It looks like you have a conflicting package that you didn't erase with Node when you ran
yum erase nodejs.
nodejs-devel-0.10.5-3.el6.x86_64 is a completely separate package. forpc.onl jiofi.local.html
yum erase nodejs.
