POLL to change the input connectors on DC switches
expohl - Member
- Been thanked: 15 times
Poll to change dc input connectors to screw terminals with dis-connectable plug
- Attachments
- 10pcs-2edg-4pin-plug-screw-terminal-block-connector-508mm-pitch-right-angle-8b8d7f69-800x800.jpg (48.09 KiB) Viewed 14336 times
Re: POLL to change the input connectors on DC switches
This is misleading. The power posts can be used as screw terminals. There is no need to use them with banana plugs.
Guys changing the connection type would require a MAJOR redesign.
The power supply is in the back and the DC terminals are in the front.
There is another long thread on the topic of the choice of connector so I don't see the point of rehashing it. I simply pointed out that the banana plugs are not required. I'm not sure the OP realizes that they are also screw terminals.
ryanm - Member
- Has thanked: 36 times
- Been thanked: 16 times
expohl wrote:Poll to change dc input connectors to screw terminals with dis-connectable plug
Phoenix connectors? No, no, no!
