accidentally disabled https?
expohl
Been thanked: 15 times
Tue Aug 18, 2015 3:34 am
I was thinking that I was going to change https to http like a ubiquiti so I didn't have to see the annoying SSL error in chrome but I think I actually disabled https entirely, does anyone know the command line command to get it re-enabled?
it's https-server something something I think?
expohl
Re: accidentally disabled https?
Tue Aug 18, 2015 3:39 am
Tue Aug 18, 2015 7:40 am
expohl wrote:so I didn't have to see the annoying SSL error in chrome
chrome://flags/#remember-cert-error-decisions
sdwisp
Has thanked: 4 times
Been thanked: 3 times
Mon Aug 24, 2015 7:35 pm
I did the same thing on the test bench and had to rest. Nice light on the reset...... :cheers:
Eric Williams
619-468-9600
SDWISP
Mon Aug 24, 2015 8:11 pm
Does anyone actually use the console port, I am seriously thinking on taking it out and use the money on other features.
You can easily turn it back on in the CLI with the console cable.
You have a FULL command set in the SSH CLI and Console.
/rant
bmv
Has thanked: 5 times
Been thanked: 12 times
Tue Aug 25, 2015 2:44 pm
sirhc wrote:Does anyone actually use the console port, I am seriously thinking on taking it out and use the money on other features.
/rant
IMO console is only useful if you really get locked out and can't get in after a factory reset/or you have not taken a backup before you need to factory reset.
If there is something that you can reset/fix with the console port that a factory reset button can't fix, then it's very important.
For everything else you should be able to log in via an IP connection?
What's the saving $$ wise?
Console port probably cost us better part of $8 so about $12 to the MSRP.
