Bonding two AF-5x Links
keefe007
Fri Aug 14, 2015 2:01 pm
What do you guys think about bonding two AF-5x links together in parallel between two towers?
I have a site I need more bandwidth at.
WisTech
Has thanked: 9 times
Been thanked: 64 times
Re: Bonding two AF-5x Links
Fri Aug 14, 2015 2:25 pm
Sounds amazing, especially if you have the spectrum to do so.
Fri Aug 14, 2015 2:55 pm
You can use LAG to bond 2 equal capacity links but keep in mind if their capacity varies too much you risk having issues.
And since the capacity will be less than the physical link state which is all Layer 2 is aware of you could have issues if you approach the aggregated capacity or one link's capacity dips too much.
You can use higher level 4 protocols such as OSPF as well
Mon Sep 14, 2015 9:23 am
Would not be AF5 in FDD mode a better choice ?
kbloch
Been thanked: 6 times
Mon Sep 14, 2015 2:48 pm
Bond the links if unequal capacity and aggregate them if equal capacity.
Advantage on either method is redundancy in case of a link failure and increased capacity when both are working.
Mon Sep 14, 2015 2:56 pm
kbloch wrote:Bond the links if unequal capacity and aggregate them if equal capacity.
As I said if they are of equal value LAG is an option but if the capacity varies you will run into trouble when traffic on one side exceeds the current capacity as Layer 2 is only physical link state aware.
