TFTP Usage
richeyrobert
TFTP Usage
Thu Aug 06, 2015 12:38 pm
I am trying to backup my switch config with TFTP. I can't seem to find and correct syntax anywhere.
I can't even seem to find the manual.
From the command line I am trying
Code: Select all
copy startup-config tftp://192.168.1.53/TowerSwitch.txt
and I get the following output:
Code: Select all
% Saving startup-config to tftp://192.168.1.53/tdc/TowerSwitch.txt
BusyBox v1.11.2 (2015-07-14 18:17:42 EDT) multi-call binary
Usage: tftp [OPTION]... HOST [PORT]
Transfer a file from/to tftp server
Options:
-l FILELocal FILE
-r FILERemote FILE
-gGet file
-pPut file
I also tried putting the same URL into the TFTP URL setting on the switch configuration page on the management page and it doesn't seem to be backing up with that setting either.
Can anyone help me figure out what I'm doing wrong? Or maybe point me to the manual?
Thanks,
Rob
Eric Stern
Been thanked: 130 times
Re: TFTP Usage
Thu Aug 06, 2015 1:08 pm
This was fixed in 1.3.0rc6, you will need to update to the latest 1.3.0 version.
viewtopic.php?f=17&t=681
richeyrobert
Re: TFTP Usage
Thu Aug 06, 2015 6:53 pm
Do you know when version 1.3.0 will be "Production ready" so I can schedule another maintenance notice?
Re: TFTP Usage
Thu Aug 06, 2015 7:13 pm
richeyrobert wrote:Do you know when version 1.3.0 will be "Production ready" so I can schedule another maintenance notice?
We do not have a firm date on this but if it gives you any confidence I am running v1.3.0rc
However we will be releasing another v1.3.0rcX in the next few days
richeyrobert
Re: TFTP Usage
Thu Aug 06, 2015 7:23 pm
Is there a way to get the config from the switch without tftp from the command line?
Is there a file that I can `scp` from the switch or anything like that?
Eric Stern
Re: TFTP Usage
Fri Aug 07, 2015 10:28 am
Yep, you can use "cmd" to get to the command line, then use scp. The config file is /www/config.json
richeyrobert
Re: TFTP Usage
Fri Aug 07, 2015 1:30 pm
A few more questions. Sorry!
Can I upload that same json file through the gui to restore a configuration?
I noticed that the config file that I download through the web interface was in some kind of binary form.
Also, to restore a configuration through the CLI, would I just upload the json file and reboot the switch? Or is there some sort of process that I would need to follow?
(By the way, thanks a ton for your quick responses. I'm really impressed with your great customer service already!)
Eric Stern
Re: TFTP Usage
Fri Aug 07, 2015 1:58 pm
You can't upload the config file in the GUI for a restore. You would scp the config file to switch, overwriting the one that is already there, and then reboot.
You are correct, the backup from the GUI is actually an archive that includes config.json and some other files like the SSL certificate. But the config file contains all the really important stuff.
