LibreNMS support for Netonix
gr0mit
Been thanked: 7 times
Sun Jul 19, 2015 1:05 pm
Hi
Just to say that I've been working with the folks at the LibreNMS irc channel to get my first Netonix switch recognised. They've just added support to the trunk so you should be able to discover it.
It now seems to support the 6 port version but I've not tested any others.
If there are any additional SNMP things that you are planning to add, I'm sure the LibreNMS folk can add it in. They seem very supportive generally and of WISPs in particular, with good UBNT and Mikrotik support.
Best regards
Tim Robinson
Basingstoke, UK
keefe007
Re: LibreNMS support for Netonix
Mon Jul 20, 2015 10:47 pm
awesome!
ColoCenter
Been thanked: 3 times
Mon Oct 12, 2015 2:48 pm
I added a WS-24-400A to my libreNMS. It's recognized, it read's the ports. But it's missing temperatures/fanspeeds etc for example. Also Vlan's aren't "seen", and the arp table isn't populated.
Other thing i have a massive spikes in the traffic graphs. Up to multiple Gbits, even 50Gbit, and that on a 1Gbit port?!?! Not sure what's causing this. Already tried switching to SNMPv1. Running firmware 1.3.3 by the way. See the graph here:
None of the other monitored devices(143) has this problem. Any suggestions here?
Alexander
