I have a new WS-12-250A and after I select a trunk, I cannot unselect them they remain with the T on them, the only way I can clear them is with a factory reset.
I have downloaded the latest firmware as instructed on the papers supplied with it.
Cannot exclude port after a trunk has been selected.
opalit - Member
Re: Cannot exclude port after a trunk has been selected.
I am guessing you are using v1.2.4 not the BETA v1.3.0rc11 because they handle this differently as v1.3.0 allows a list not just all.
I am not sure I follow you for sure but if you are referring to the Trunk (allow all VLANs) check box above each port #?
When you check that box it will put a T for Tagged on all defined VLANs below for that port.
Now if you remove the check from the check box you will have to click on all the Ts below on each VLAN and manually turn them back to E for Exclude or U for Un-tagged.
You can always click the browser refresh button at anytime before clicking Save/Apply to throw away any changes
opalit - Member
sirhc wrote:I am guessing you are using v1.2.4 not the BETA v1.3.0rc11 because they handle this differently as v1.3.0 allows a list not just all.
That is the problem when I click the T nothing happens on Ports 1, 2 and 12 but it works on other ports.
i will look at this tomorrow and consult with Eric for you and see whats up.
I am sitting at home today sweating my behind off as my central air died last night and we are getting sunny 98F weather with 75% humidity.
Global warming is a myth!
I should go into work as the whole warehouse has AC and is a cool 72F
opalit - Member
sirhc wrote:i will look at this tomorrow and consult with Eric for you and see whats up.
I am sitting at home today sweating my behind off as my central air died last night and we are getting sunny 98F weather with 75% humidity.![]()
Global warming is a myth!![]()
98 what's that in English, I was up at 4:00AM switching people over to my new fibre line, and this switch is required to replace the existing MikroTik router on the old link as I join all the existing Ubiquiti radio links on the mountain together.
Global warming is a myth, I have a copy of the doctored information that proves it.
opalit wrote:Global warming is a myth, I have a copy of the doctored information that proves it.
Big Oil says CO2 levels are JUST FINE, when did big oil ever tell us anything that was not true?
I think that LEAD in OK as a gasoline additive maybe in the 60s and 70s?
Besides if the ocean levels raise high enough I could end up with Ocean Front property - SCORE!!!
98F is only 37C but the 75% humidity is the problem.
opalit - Member
Doctored info does not lie, Global Warming is a money making scam
Eric Stern - Employee
- Been thanked: 130 times
Can you post a screenshot of your VLAN tab?
opalit - Member
sirhc wrote:opalit wrote:Global warming is a myth, I have a copy of the doctored information that proves it.
I have seen copies of leaked emails between scientist all over the world who colluded and manipulated the data, in particular the so called hockey stick graph.
There is a Mountain in Spain called Montserrat, embedded in the rocks at the summit are fossils of sea creatures and sea shells, it was once under water, the sea will have to rise an awful lot to get back to those days.
When ice in the sea melts it does not cause the water level to rise, try it, drop an ice cube in a glass of water, mark the glass and check it after it has melted.
Global warming is a scam to tax people more and make a fortune out of useless wind turbines.
