Connecting 8 cognex cameras to ports 1-8 with POE on a 12 port WISP switch.
We have done 4 of these setups, so far two of the four switches we have configured continuously power cycle.
I have confirmed updates to 1.5.26 firmware.
Also, I have statically configured switch IP to 172.16.17.100....
Aside from that, I am only using the Ports tab to set each port 1-8 for 48V .75 amp settings.
Any ideas what I am doing wrong?
If I bring up the ports, one by one, the system will be stable... However, I cannot get the switch to survive a reboot. Once I reboot, the switch will continuously power cycle.
We have 22 switches to configure, but since 2 of the first 4 are doing this, I am reaching out for guidance.
Cheers and best regards!
Dan Gieseman
WS-12-250-DC continuous power cycling
- daniel.gieseman@syngenta.com
Dave - Employee
- Been thanked: 159 times
Re: WS-12-250-DC continuous power cycling
kinda sounds like your power source you are using for the switch doesn't have enough current capability to handle the load surge when switch is turning on...
