LinkRunner G2 can't test for POE?
We have a netAlly Linkrunner G2 tester which among other things will report back POE statistics of a Port. However it does not seem to work with Netonix switches. I get Layer 3 and it passes traffic, but it says POE not detected with the Netonix set to 24v, 48v or 48vh. I've never had this issue with any other switch, just Netonix.
sakita - Experienced Member
- Has thanked: 112 times
- Been thanked: 90 times
Re: LinkRunner G2 can't test for POE?
I don't have one of those testers but a quick look at the manual says there is an "Injector" option setting which sounds like it is used to ignore IEEE PoE handshaking. Are you using that mode and / or have you tested other non 802.xx passive PoE switches like the Netonix?
