I am attempting to setup the Netonix Manager so I can remotely manage switches that are located across the NA region.
Is it not possible to add multiple switches from the same source IP but different HTTP port?
We may have a workaround, but I want to check if I am missing any key details.
As an FYI since there is no documentation:
If your netonix switch is behind a router, you need the HTTP and SSH port traffic opened.
Netonix Manager - Adding Switches from same IP
- exewiz
- exewiz
Re: Netonix Manager - Adding Switches from same IP
Update, I realized the devices need a unique SSH and HTTP port if there are several behind the same address.
Follow-up question, where in the files is that information stored? Is there any way to add devices en-mase via editing one of the files?
exewiz wrote:Update, I realized the devices need a unique SSH and HTTP port if there are several behind the same address.
Yup, that is pretty much how it has to work regardless of gear located behind a NAT single address.
And as you said setup port mappings in your router to each device behind a NAT.
No, sorry you will have to add them 1 at a time.
Users browsing this forum: No registered users and 25 guests
