I noticed that 1.2 still has the bug that VLAN trunking doesn't work unless one VLAN is added to the switch.
Thanks!
Keefe
VLAN bug in 1.2
Re: VLAN bug in 1.2
What is the MTU you are using?
- keefe007
Re: VLAN bug in 1.2
I know the bug is still there because when i added a random vlan (ie, vlan 500) it let everything through like it should.
Re: VLAN bug in 1.2
When you say v1.2 do you mean v1.2.2 or v1.2.0
OK thanks, I will inform Eric
I am hoping to finalize v1.3.0 soon but we may release a v1.2.3 before that
Re: VLAN bug in 1.2
Thanks.
It might be a couple days until we release a new version v1.2.3 and a new v1.3.0rc10 as Eric is trying to get over a hump with the CAP boards.
We just got him some new CAP boards to play with.
But you know how to work around it for now?
