Mini inrush
rkelly1
Has thanked: 12 times
Been thanked: 27 times
Mini inrush
Sun Jul 05, 2015 8:30 pm
Searched forum but didnt' see the answer. Chris, what is the inrush current on the mini at startup?
Re: Mini inrush
Sun Jul 05, 2015 8:40 pm
if it is not powering anything, just the switch itself not very much.
I do not think we tested that but it can not be 20W but I guess it would depend on the accuracy of your measuring device and how small of time increment.
Been thanked: 159 times
Re: Mini inrush
Sun Jul 05, 2015 8:51 pm
it is kept low because the power circuit has a soft start function, but I will have to measure one to give you an actual number, will try & do tomorrow...
rkelly1
Re: Mini inrush
Tue Jul 07, 2015 11:14 pm
Any progres s testing inrush?
Re: Mini inrush
Tue Jul 07, 2015 11:56 pm
inrush is from 0 to about 0.8 amps, linear ramp for about 15mSec in duration.
rkelly1
Re: Mini inrush
Wed Jul 08, 2015 8:44 am
Thx. Take it that is with no poe loads. Any idea what it would be with 5 ports 24v poe on? Or does it also depend on what is plugged into the ports at startup?
Re: Mini inrush
Wed Jul 08, 2015 9:10 am
rkelly1 wrote:Thx. Take it that is with no poe loads. Any idea what it would be with 5 ports 24v poe on? Or does it also depend on what is plugged into the ports at startup?
Depends on what devices it is powering and what their inrush draw is however the switch will not power up the POE until it is booted then staggers the port POE turn ups so it is not like all of them are at one shot.
rkelly1
Re: Mini inrush
Wed Jul 08, 2015 9:44 am
Good deal. Thanks.
