Netonix Manager update
fbeneventi
Fri Mar 28, 2025 12:13 pm
Hello,
My Netonix Manager acting strange lately.
Basically need to reboot server after few hours of use.
It is running 1.17 version and showing 1.24 is available but when I click 'update' it either crashes or just shows it is updating and it takes forever but at the end nothing happen.
So, I wanted to ask what is correct procedure to spin up brand new Netonix Manager. Is it OK to install new Manager and then one by one switch first remove from old server and then adopt in new one?
I saw warnings about two Netonix Manager instances, so wanted to make sure how to proceed.
Thanks.
JeffreyS
Has thanked: 8 times
Been thanked: 10 times
Re: Netonix Manager update
Fri Mar 28, 2025 1:16 pm
On my Windows based Network Manager I had the same issue trying to update. I had to download directly from the website and install.
netonix-manager/
fbeneventi
Fri Mar 28, 2025 7:34 pm
So, after you installed new one, did you ever had both Netonix Manager up at the same time?
I saw warning - never have 2 managers.
JeffreyS
Mon Apr 14, 2025 10:54 am
No. It upgraded the existing installation.
Mon Apr 14, 2025 12:20 pm
Never run 2 managers.
Remove old one or both and reinstall.
Users browsing this forum: No registered users and 24 guests
