# Moved from WISP
I can ssh in with the user and pw, but not the web interface - error message: Invalid username or password. I've cold reloaded, tried killall and restart, nothing. Any tips here?
This is the current version:
**************@Netonix_Switch:/www# cat version.txt
1.5.25
I've tried the current password as well as the admin/admin default. Nothing gets through.
Here are the config.json.
fadmin@Netonix_Switch:/www# cat config.json
"Config_Version":9,
"IPv4_Mode":"Static",
"IPv4_Address":"***********",
"IPv4_Netmask":"***********",
"IPv4_Gateway":"***********",
"IPv4_Primary_DNS":"***********",
"IPv4_Secondary_DNS":"",
"IPv6_Enable":false,
"IPv6_Mode":"DHCP",
"IPv6_Address":"",
"IPv6_Gateway":"",
"IPv6_Primary_DNS":"",
"IPv6_Secondary_DNS":"",
"Switch_Name":"Netonix Switch",
"NTP_Zone":"America\/New York (EST5EDT,M3.2.0,M11.1.0)",
"Switch_Location":"",
"GPS_Latitude":"",
"GPS_Longitude":"",
"Credentials_Name":"***********",
"Credentials_Password":"",
"Credentials_HashedPassword":"***********.6bg",
"Credentials_NewHashedPassword":"$2b$10$***********.SnfMmLr6AFJa7tpSKRHK9njLKam",
"Credentials_Console_Login":false,
"RADIUS_Enable":false,
"RADIUS_Host":"",
"RADIUS_Port":"1812",
"RADIUS_Secret":"",
"SSH_Enable":true,
"SSH_Port":"22",
"SSH_Allow_Passwords":true,
"SSH_Allow_Telnet":false,
"SNMP_Server_Enable":false,
"SNMP_Server_Community":"public",
"SNMP_Server_Contact":"",
"SNMP_Server_Location":"",
"SNMP_Server_Version_1":false,
"SNMP_Server_Version_2c":false,
"Syslog_Enable":false,
"Syslog_Host":"",
"Syslog_Port":"514",
"Syslog_Exclude":"",
"Syslog_Buffer_Size":"128",
"Syslog_Log_Logins":false,
"Syslog_Log_Name":false,
"SMTP_Enable":false,
"SMTP_Host":"",
"SMTP_Port":"25",
"SMTP_Username":"",
"SMTP_Password":"",
"SMTP_Secure":false,
"SMTP_Address":"",
"SMTP_From_Address":"",
"SMTP_Local_Hostname":"",
"NTP_Enable":false,
"NTP_Host":"",
"STP_Enable":true,
"STP_Version":"RSTP",
"STP_Max_Age":"20",
"STP_Hello_Time":"2",
"STP_Forward_Delay":"15",
"STP_Priority":"32768",
"STP_LAG_Enable":true,
"Storm_Control_Broadcast":"None",
"Storm_Control_Multicast":"None",
"Storm_Control_Unicast":"None",
"Storm_Control_Loop_Protection":false,
"Storm_Control_Pause_Frame":true,
"HTTPS_Enable":true,
"HTTPS_Port":"443",
"HTTPS_Allow_HTTP":false,
"HTTPS_HTTP_Port":"80",
"AggregationMode_DestinationMAC":false,
"AggregationMode_SourceMAC":false,
"AggregationMode_SourceDestinationIP":true,
"AggregationMode_SourceDestinationPort":false,
"Tarpit_Enable":true,
"Tarpit_Attempts":"5",
"Tarpit_Delay":"60",
"Discovery_Ubiquiti":false,
"Discovery_Cisco":false,
"Discovery_LLDP":false,
"Power_Hibernate_Voltage":"9",
"Power_Wakeup_Voltage":"10",
"Power_Warning_Voltage":"11",
"Options_IGMP_Snooping":false,
"Options_MAC_Aging":"300",
"Options_Language":"en",
"Serial_Mode":"Console",
"Serial_TCP_Port":"502",
"Serial_Baud_Rate":"115200",
"Serial_Parity":"N",
"Serial_Data_Bits":"8",
"Serial_Stop_Bits":"1",
"Email_Alerts_Link_Change":true,
"Email_Alerts_Flow_Control":true,
"Email_Alerts_DC_Power":true,
"Email_Alerts_Fans":true,
"Email_Alerts_PoE":true,
"Email_Alerts_LACP":true,
"Discovery_Discovery_Tab":false,
"Discovery_Broadcast_On_Protocols":true,
"Switch_Revert_Timer":"300",
"Applied":true,
"MSTP_Name":"",
"MSTP_Revision":0,
"Auto_Backup_Enable":false,
"Auto_Backup_TFTP_URL":"",
"VLANs":[
"ID":"1155",
"Name":"Management",
"Enable":true,
"PortSettings":"UUUUUUUUUUUUUU",
"IPv4_Enable":false,
"IPv4_Address":"",
"IPv4_Netmask":"",
"IPv6_Address":"",
"IGMP_Querier":false
"ID":"256",
"Name":"***********",
"Enable":true,
"PortSettings":"EEEEEEEEEEETEE",
"IPv4_Address":"",
"IPv4_Netmask":"",
"IPv6_Address":"",
"IGMP_Querier":true
"Ports":[
"Number":1,
"Name":"Port 1",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"FlowControl":"None",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STPPriority":"128",
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"DHCP_Snooping":false,
"Shutdown_Voltage":"",
"Restart_Voltage":"",
"Priority":"1",
"Shutdown_Time":"",
"Startup_Time":"",
"Boot_Start_Delay":"",
"Updated_SFP2":true,
"QoSSched":"Strict",
"PoE_Smart":true
"Number":2,
"Name":"Port 2",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"2",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":3,
"Name":"Port 3",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"3",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":4,
"Name":"Port 4",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"4",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":5,
"Name":"Port 5",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"5",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":6,
"Name":"Port 6",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"6",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":7,
"Name":"Port 7",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"7",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":8,
"Name":"Port 8",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"8",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":9,
"Name":"Port 9",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"9",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":10,
"Name":"Port 10",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"10",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":11,
"Name":"Port 11",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"11",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":12,
"Name":"900 mhz radio",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"12",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":13,
"Name":"Port 13",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"13",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"Number":14,
"Name":"Port 14",
"Enable":true,
"Link":"Auto",
"PoE":"Off",
"Multicast":true,
"MTU":"1528",
"TxLimit":"",
"RxLimit":"",
"STP":true,
"STP_Path_Cost":"",
"Stats":true,
"Isolation":false,
"AllowedVLANs":"",
"Priority":"14",
"Shutdown_Time":"",
"Startup_Time":"",
"PoE_Smart":true
"LACP":[
"Port":1,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":2,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":3,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":4,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":5,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":6,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":7,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":8,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":9,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":10,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":11,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":12,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":13,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"Port":14,
"Enable":false,
"Key":"",
"Role":"Active",
"Timeout":"Fast",
"Priority":"32768"
"MSTI":[
"Priority":"32768",
"VLAN_List":"",
"Ports":[
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"32768",
"VLAN_List":"",
"Ports":[
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"32768",
"VLAN_List":"",
"Ports":[
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"32768",
"VLAN_List":"",
"Ports":[
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"32768",
"VLAN_List":"",
"Ports":[
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"32768",
"VLAN_List":"",
"Ports":[
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"32768",
"VLAN_List":"",
"Ports":[
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Priority":"128",
"Path_Cost":""
"Mirror":{
"Port":"None",
"RemoteHost":"",
"Filter_MAC":"",
"Filter_IP":"",
"Ports":[
"SSH_Keys":[
"PingWatchdogs":[
"PortBounces":[
"AccessControls":[
"ERPS":[
"MEPs":[
"QoSRules":[
Updated FW but now can't log in via http - 'invalid pw
Re: Updated FW but now can't log in via http - 'invalid pw
Ssh into swithch set credentials in ssh to something new.
Hit enter in ssh to confirm changes
Change credentials back to what you want again hit Enter afterwards to confirm.
Try UI
Other than that you may have a corrupted config. Factory default manually set up.
Try UI
kennaster - Member
- Has thanked: 15 times
Got it, as you suggested.
ssh'd into switch
dropped to linux 'cmdline'
changed the pw with 'passwd'
UI log in success.
Problem solved thanks!
ssh'd into switch
UI log in success.
kennaster wrote:Got it, as you suggested.
ssh'd into switch
UI log in success.
Not sure why you dropped to Linux.
Ssh in ? [Enter]
There is a comman called credentials in the list i think.
Our shell has help at every point with "?" [Enter]
Do a partial command "?" [Enter]
Credentials password ????????
Credentials user ???????
Not sure changing password at Linux level full effect?
