Netonix "Seized" by FBI
joeyr-stc
Has thanked: 5 times
Been thanked: 4 times
Fri Aug 02, 2024 11:26 am
One of my Netonix switches (WS-8) on ver: 1.5.16 had its webserver "seized" by the FBI (see attached image). It is claiming that the device is acting as a 'DDoS-for-hire service'.
I went to access the webserver to program the unit and instead I was presented with the attached image.
The link embedded in the image is legit (https://www.fbi.gov/contact-us/field-of ... os-attacks).
This is VERY worrisome. How did my device get compromised so that the webpage was re-written? And, why does the FBI think it is being used for DDoS?
I have pulled the device from production and accessed it directly from my laptop (nothing else plugged in) and I get the same message. So, this is not a re-direct. Somebody actually got access to the underlying webserver and rewrote the default index.html page. If I go to main.html, or index.php, I get the correct login screen.
I have not factory defaulted the device to see if that fixes the issue. I want to see if there is anything that can be gleamed from its current state.
The switch still works.
Please advise what needs to be done.
Joey Robertson
STC
Mobile, AL
Re: Netonix "Seized" by FBI
Fri Aug 02, 2024 12:06 pm
Go to proper thread
viewtopic.php?f=17&t=8066
