POE power limiting to 802.3af
apadmin
Tue Aug 16, 2022 1:10 pm
Is there a way to limit the amount of watt's that can be drawn by a single port? For instance I'm looking to make sure my Access Point can run at 802.3af and not 802.3at due to power limitations of a Netonix WS-6-MINI.
Thanks,
Dan
KBrownConsulting
Has thanked: 15 times
Been thanked: 18 times
Re: POE power limiting to 802.3af
Tue Aug 16, 2022 7:56 pm
To the best of my knowledge there's no way to control the amount of power a port can deliver on any Netonix switch. The DC switches have a priority option on the Power tab that control the order devices get powered up/down as the battery loses power, but that doesn't apply to the AC switches.
apadmin
Wed Aug 17, 2022 1:58 am
What would the switch do if there is not enough power for all the devices? Does it allow one device to pull all the power or does it equally distribute?
