Hang upon hostname change from CMDline
yahel
Has thanked: 22 times
Been thanked: 22 times
Wed May 27, 2015 12:11 am
Been remotely configuring a switch in the field using command line...
This command got the switch to hang (equipment remain powered, but no ping):
Code: Select all
 Netonix Switch(config)# hostname Cory-Netonix-SW
Will try to drive out there tomorrow to reboot ;-(
(latest stable firmware - don't recall from memory what is the version number).
Eric Stern
Been thanked: 130 times
Re: Hang upon hostname change from CMDline
Wed May 27, 2015 9:58 am
Did you make any other configuration changes before changing the hostname?
Users browsing this forum: No registered users and 25 guests
