Please make reports about SFP+ modules that do or do not work here for the WS3 family of switches and they will be added to the first post here accordingly.
WORKS:
Cisco SFP-10G-LR
Cisco SFP-H10GB-CU50CM
10GTek 10GBase-T SFP+ Transceiver
FLYPROFiber 10GBase-T SFP+ Transceiver
Dimiks SFP-10G-T
Zopsc SFP-2.5G-LX20-SM1310
Macroreer 10GBASE-SR
QSFPTEK 10GBASE-SR
FluxLight SFP-10G-SR
10GTek ASX85-192-M3
YuanLey SFP-10G-SR
Mikrotik S+31DLC10D
FireBuy QSFP-4X10G-DAC03
Mikrotik S+DA0001
DOESN'T WORK:
Compatible SFP+ Modules (WS3) - FIRST POST IS COMPILED LIST
- Been thanked: 210 times
Re: Compatible SFP+ Modules (WS3) - FIRST POST IS COMPILED L
Moving
Mikrotik S+31DLC10D
to working
If anyone running v2.0.6 is having trouble with those module's and possibly others, please try downloading and re-installing v2.0.6 see this thread for details
Mikrotik S+31DLC10D
to working
MikroTik S+85DL03D transceivers work with some effort. On a defaulted switch the sfp+ port has to be linked up at 1G then set to 10G or else it won't link up (tested between a MikroTik router and a WS3)
Garnet wrote:MikroTik S+85DL03D transceivers work with some effort. On a defaulted switch the sfp+ port has to be linked up at 1G then set to 10G or else it won't link up (tested between a MikroTik router and a WS3)
I see this same issue with FS.com transceivers that are flashed for Mikrotik. Fresh out of the box it will not link up at 10g until you set the port for 1g, establish a link and then change it to 10g.
- jacsa
WORKS:
Ubiquiti UDC-3 SFP+ Direct Attach Copper Cable 10 Gbps
- michaeln416
- Has thanked: 8 times
- Been thanked: 7 times
Does NOT work:
MikroTik SFP+RJ10 (copper ethernet transceiver)
https://mikrotik.com/product/s_rj10
The moment I plugged it in, the WS3 rebooted.
Running firmware 2.0.8
Note: I did not wait for the WS3 to reboot to see if the unit started to work. I quickly removed it as the reboot caused a significant unplanned outage.
