DC switch isolated input?
petecarlson
Has thanked: 15 times
Been thanked: 10 times
Fri May 15, 2015 1:45 pm
Are the inputs on the DC switches going to be isolated, i.e. not referenced to ground, so that we can connect it to a standard -48VDC rectifier shelf?
Been thanked: 159 times
Re: DC switch isolated input?
Fri May 15, 2015 1:48 pm
Yes, isolated, as in not references to chassis ground
Fri May 15, 2015 1:51 pm
However our ESD RJ45 connectors are connected to the Chassis which should be binded to Earth ground so keep that in mind.
