Netonix Switch ws-8-150-ac
evanp
Wed Jan 06, 2021 7:19 am
I need to put some time delay on PoE port activation and I was wonder if there is an option for Time delay in PoE Management on that particular switch? Or is there a way using CLI/SSH to configure that with commands?
Kind regards
Evan
Been thanked: 210 times
Re: Netonix Switch ws-8-150-ac
Wed Jan 06, 2021 4:47 pm
Yes, in the Power Tab, you can input in seconds to the Boot Start Delay for a port and when the switch boots it will not turn on PoE on that port for the specified time.
evanp
Wed Aug 11, 2021 7:01 am
Thanks for the reply Stephen
We have been using that setting for some netonix on the field and it works great. However is there a suggested time I should put between ports delay?
For example we have 3 PoE ports and I do the following:
Port Boot Start Delay
1 15
2 5
3 10
They boot up all at the same time still. I would expect 15 seconds on port 1 delay etc.
The version on that switch is v1.5.2
Kind regards
Evan
