IGMP Snooping
jifop
IGMP Snooping
Tue Nov 17, 2020 10:56 am
Hello All, I've been testing with a netonix wisp mini and IGMP Snooping is not working as expected.
Using MC Hammer I'm running multicast data tests and the Netonix is broadcasting on all ports not the one receiving multicast, this occurs with IGMP Snooping on or off.
The same test using a Luminex Gigaswitch works flawlessly.
Can anyone advise?
Tim
Been thanked: 210 times
Re: IGMP Snooping
Wed Nov 18, 2020 11:32 am
IGMP Snooping and Multicast have been long running issues. Right now if the snooping fails you should be able to re-activate it by simply turning IGMP Snooping off and on again. (Also, make sure you are running the latest firmware, presently 1.5.6)
jifop
Re: IGMP Snooping
Thu Nov 19, 2020 2:01 pm
Oh dammit I wasn't aware of that.
Turning snooping on and off every day isn't really an option but nor is broadcasting the multicast data.
I guess I will reserve this switch for smaller networks.
