Mikrotik SFP Compatibility
frank
Mon Apr 27, 2015 6:34 am
Can anyone confirm Mikrotik SFP S-31DLC20D or S-85DLC05D are compatible for Netonix WISP Switch WS-12-250A ?.
http://routerboard.com/S-31DLC20D
http://routerboard.com/S-85DLC05D
Frank
Re: Mikrotik SFP Compatibility
Mon Apr 27, 2015 9:39 am
I do not know if they are compatible but there was fixes put into the 1.2.0rcXX which was for MicroTik SFP modules so if you try then with v1.1.8 and they do not work please upgrade to v1.2.0rc11 and try that.
adairw
Has thanked: 98 times
Been thanked: 132 times
Sun May 03, 2015 10:58 am
I'm using some copper mikrotik sfp's in my switches and they work fine. I would think the fiber modules would also. I have some laying around that are just like what you posted. I'll give them a go and let you know.
frank
Wed May 20, 2015 12:36 pm
Mikrotik SFP S-31DLC20D doesn't seems to be working in the switch. Is there any fix which addresses the Mikrotik SFPs ?/
Wed May 20, 2015 12:58 pm
frank wrote:Hi,
WHat version of Firmware are you running?
frank
Wed May 20, 2015 6:27 pm
version 1.2.0
Eric Stern
Been thanked: 130 times
Wed Jun 03, 2015 2:25 pm
frank wrote:Hi,
I ordered these and they arrived today. Tested on several switches running 1.2.0 and up and they seem to work fine.
LRL
Has thanked: 19 times
Been thanked: 49 times
Fri Jun 19, 2015 2:13 am
I had tested these a couple of weeks ago on 1.2.2 Board Rev B and they didn't work when linking to a CCR1036. I will have to re-test to make sure.
-LRL
LRL
Tue Jun 23, 2015 3:00 am
Here is the deal with the Mikrotik S-31DLC20D modules. They work fine from WISP switch to WISP Switch and from Mikrotik to WISP.
Mikrotik's devices have Auto Negotiation turned on for their SFPs by default, you have to disable auto if you want to link mikrotik to WISP switch. This is a pretty standard issue, but I thought I'd mention it.
I was mistaken, it's the mikrotik s-53lc20d -- s-35lc20d modules that don't work.
We have a tower site that we have 6 stands of SM fiber ran into it. Initially we were only using a pair, but now we're running three fiber drops to other near by towers and we've been forced to resort to the WDM modules.
-LRL
