GUI doesn't load in IE9
sbyrd
Has thanked: 16 times
Been thanked: 26 times
Fri Apr 24, 2015 3:06 pm
I did not know if you were aware that the web GUI does not load properly in IE9?
wayneorack
Has thanked: 188 times
Been thanked: 64 times
Re: GUI doesn't load in IE9
Fri Apr 24, 2015 4:00 pm
Chrome is the only officially supported browser. You may try others, but results will vary.
Been thanked: 159 times
Fri Apr 24, 2015 4:42 pm
I use Firefox & GUI works fine with it....never tried IE at all....
Fri Apr 24, 2015 5:08 pm
sbyrd wrote:I did not know if you were aware that the web GUI does not load properly in IE9?
IE9 - Umm no we do not guarantee that it will work with a several year old browser, please upgrade to IE11 and life will be better!
IE9 was released in 2011, I hardly doubt all the "newer" extensions and snap ins will work that that old of software.
I am also sadly reporting that I can not get the web UI to work with my Tandy TRS-80! :rofl4:
