SNMPv2 Support
frank
SNMPv2 Support
Thu Apr 23, 2015 6:04 pm
Which WISP switch firmware version supports SNMPv2 / SNMPv2c ?. I am using version v1.1.5 which has SNMP v1.
- Frank
Re: SNMPv2 Support
Thu Apr 23, 2015 6:18 pm
frank wrote:Hi,
- Frank
you can read the release notes in the firmware download thread. viewtopic.php?f=17&t=240
Start at the last page and read up, no sense reading about early release stuff
frank
Re: SNMPv2 Support
Wed Apr 29, 2015 11:25 am
After upgrading the WISP switch vo v1.2CR11, I can confirm that SNMPv2 is working for GET operation. However, I found the following issues.
1. SNMP get on the firmware revision returns unwanted result.
NETONIX-SWITCH-MIB::firmwareVersion.0 = Wrong Type (should be OCTET STRING): INTEGER: 1649569185
2. Couldn't see any SNMP trap raised from the WISP switch.
3. Couldn't find any option to set the SNMP trap server IP address.
Eric Stern
Been thanked: 130 times
Re: SNMPv2 Support
Wed Apr 29, 2015 11:46 am
I'll make a note to fix the firmware version type in the MIB.
SNMP traps are not supported at this time.
