Hey Everyone,
I have a question about these mini switches and I am hoping that I can get a answer to it and I apologize in advance if this is a dumb question. So I understand that port 1 is a special port and the documentation states:
Note:
Port 1 will accept passive 48VH (48-56V) using all 4 pairs like a POE
injector used to power an airFIBER 24 GHz.
however, since that port has an indicator light that shows that is is 24V but when I log into the switch it says the PoE is off, can i safely use that as a local LAN connection on a customers network? or if not which port do you recommend?
Thanks Everyone!
WS-6-Mini Port 1
- robertwf
Dawizman - Experienced Member
- Has thanked: 17 times
- Been thanked: 31 times
Re: WS-6-Mini Port 1
Yes, there is no power. Use it as PoE input, or as a non PoE port.
robertwf wrote:however, since that port has an indicator light that shows that is is 24V...
Actually they use that LED to indicate the switch has power, not that the port has PoE enabled.
On the following page it states:
https://netonix.com/wisp-switch/ws-6-mini.html
If powering the WS-6-MINI with a 48-56V barrel connector power supply
port 1 has no POE options, it is just a standard Ethernet port.
