Can someone clarify the dimensions of the WS-12-250-AC?
I see the dimensions are listed as 223 mm x 181 mm x 44 mm on the product page but the angle & potential perspective distortion of the single picture leaves some question about which dimension is which... Is the switch wider or longer? (It looks to me like the width side to side is greater than the depth front to back... is that correct?)
WS-12-250-AC Dimensions
KBrownConsulting - Member
- Has thanked: 15 times
- Been thanked: 18 times
Dave - Employee
- Been thanked: 159 times
Re: WS-12-250-AC Dimensions
223 mm (wide..side to side looking at front of switch)
181 mm (deep...front to back)
44 mm (height)
44 mm (height)
Just wanted to say thanks for the quick reply Dave! (I did see it the same day which was helpful!)
