Hey all, anyone know if there's a convenient way to disable paging when SSHed into the CLI? I'm working on some custom Nornir/Netmiko config backup automation and having to press Space or Enter to get the full config is causing a bit of a headache. It's not impossible to get around this, just figured I would ask first over here before rewriting the Python scripting.
Thanks!
Disable CLI paging
- socraticmethod
- socraticmethod
Re: Disable CLI paging
Rather than paging through the show config output I found it easier to enter the cmdline context and simply copy the config.json file.
For anyone else using Nornir/Netmiko for config backups, copied below is the Python script to get it done.
- Code: Select all
from nornir import InitNornir
from nornir.plugins.tasks.files import write_file
from nornir.plugins.tasks.networking import netmiko_send_command
from nornir.plugins.functions.text import print_result
import pathlib
# Initialize Nornir with config file
nr = InitNornir(config_file="config.yaml")
# Get list of devices by OS / Platform
devices = nr.filter(platform="netonix")
# Configure device connection settings
def backup_netonix_config(task):
task.host.open_connection(
"netmiko",
configuration=task.nornir.config,
platform="linux",
port="22",
username="yourusername",
password="yourpassword",
# Create backup directory and enter cmdline context on Netonix
backup_dir = "config-backups/"
pathlib.Path(backup_dir).mkdir(exist_ok=True)
task.run(
task=netmiko_send_command,
use_timing="True",
command_string="cmdline",
delay_factor=2,
# Concatonate config.json file
output = task.run(
use_timing="True",
command_string="cat config.json",
delay_factor=2,
# Write hostname with config output to config-backups folder
task.run(
task=write_file,
content=output.result,
filename=str(backup_dir) + task.host.name,
# Launch script and make it all happen
def main():
result = devices.run(task=backup_netonix_config, num_workers=100)
print_result(result, vars=["stdout"])
main()
